Greetings
Peplink SOHO router works great but :
Does anyone have any explicit directions to set up a remote connwection on an apple iphone ? Due to NOTR having PPTP I cannot get L2tp with ipsec to work
We need to log in via iphones but for the life of me I tried but am unable to make it work
Thx
Rich
@Richard_OConnor, The easiest would be to not use either of those options and select the OpenVPN connection for incoming connections. Set that method up, download the config file.
On the iphone download OpenVPN client app, add the config file you downloaded previously.
This is the method I use for remote connections, haven’t had any issues with it.
Mornin ! Just got your msg !
Never knew you could download it to your iphone as i thought it was not supported on the i phone
Where do I find the config file ? Not sure I understand as I just downloaded the app
Thx as I’ll give it a shot !!
Interesting …
