Hi All,
I currently get an annoying intermitent issue with my two HD1
Here is how I have it setup:
HD4 MBX: my main router with 2 cellular modules available and 2 Active WAN ports.
WAN1: HD1 Dome with its respective XSIM.
WAN2: HD1 Dome with its respective XSIM.
Now and again, with the web GUI of the HD1’s open, it will give me “unable to reach web admin” and I believe the MBX doesn’t send traffic through, even that the WAN appears as Connected.
Is someone else experiencing something similar? I have checked the router when it does this and it doesn’t seem to reboot itself.
Here is what it shows on the MBX event log:
| Aug 08 14:44:51 | WAN: HD1 Dome 2 disconnected (WAN failed DNS test) |
| Aug 08 14:41:38 | WAN: HD1 Dome 2 connected (192.168.50.13) |
| Aug 08 14:41:37 | WAN: HD1 Dome Aft Mast connected (192.168.60.10) |
| Aug 08 14:38:43 | WAN: HD1 Dome Aft Mast disconnected (Disabled) |
| Aug 08 14:38:40 | WAN: HD1 Dome 2 disconnected (Disabled) |
| Aug 08 14:28:52 | WAN: HD1 Dome 2 connected (192.168.50.13) |
| Aug 08 14:27:56 | WAN: HD1 Dome 2 disconnected (Disabled) |
| Aug 08 14:14:39 | WAN: HD1 Dome 2 connected (192.168.50.13) |
| Aug 08 14:14:29 | WAN: HD1 Dome 2 disconnected (WAN failed DNS test) |
| Aug 08 14:11:57 | WAN: HD1 Dome 2 connected (192.168.50.13) |
| Aug 08 14:11:51 | WAN: Unable to detect MTU for HD1 Dome 2. Fall back to 1440. |
| Aug 08 14:10:46 | WAN: HD1 Dome 2 disconnected (WAN failed DNS test) |
Thank you,
J
