Unable to log into 192.168.100.1 RouterLogin
#1
Hello, This is my first post in the forum please be humble if I had posted in the wrong category
Unable to log into Router, IP is 192.168.100.1. Recently someone has accessed into its security setting, how to log on to it now?
#2
Hello @Simrahperalta,
If your balance router is still within waranty, then you may be able re regain control by setting it up within the Peplink InControl2 platform, for a guide on setting up InControl2, take a look at the InControl 2 Initial Setup Guide.
If someone else has already gone and put the router on InControl2 then they have control of your router and for you to regain control of the router (if you do not know who has that control) you will need to raise a support thicket here at Contact Us, post your Peplink ticket number here so the Peplink staff can see and they will get back to though the support ticket moving forward.
You can also factory reset the balance rotuer and set it up again if needed, there is the option to prevent the balance router being controled by InControl2 if you wish, this option will need to be choosen before you connect the balance router to the internet.
Happy to Help,
Marcus :slight_smile:
#3
Are you using correct IP address? Most of the time IP address is 192.168.0.1. At first, find out whether you’re using default IP address of your router or not. You can easily find it below your router. Default user & password is also available there.
