MAX BR1 Pro 5G, have updated firmware to 8.5.0, and purchased a CarePlus+ plan, but I do not see the ‘eSim Activation’ option in Device > Settings ![]()
How can I resolve?
How can I resolve?
To add to @MarceloBarros response.
Login to https://incontrol2.peplink.com
The device needs to be online and added to incontrol2.
Navigate to the device Group, you will see (Group Level) on the navigation bar.
Click on the device, you will see (Device Level) on the navigation bar.
Click the Settings gear icon → Select Device tools.
Click Esim activation.
Many thanks, it is in the drop down list this morning, maybe it took sometime to update/poopulate after I purchased the PrimeCare+ package.
It looks easy enough to do. My current SIM provider does not offer esims, but i can swap providers easy enough. So I think tha t makes the Antenna Max an option for me.
Appreciate all your help.
