Unable to access Web Admin From LAN after enabling & Disabling WAN Remote access
Following the COVID-19 lockdown, I enabled WAN access to the device to be able to access the device from the Internet and it worked.
Later when I came back to office, I disabled remote access from the Internet but left LAN access intact, applied changed and then I was locked out! I couldn’t access it from the LAN anymore even after several reboots. How can I resolve this?
Hi @luper11, welcome to the Forum.
If the device is still within Warranty, then you can add it to InControl and manage it there remotely - this is safer than using the WAN IP Address. You can create an InControl Organisation > Here < - add a group (this is just any name that you want to give it) and then add the serial number of the device you are using.
You can then access / manage / control the device remotely.
If you need any help setting this up, feel free to send me a DM on here.
Steve
Hey Steve,
thanks for the reply. Just wondering, will this guarrante that I can remote into the device?
InControl has worked for me to ensure accessibility, but be aware of the settings that propagate admin passwords to InControl controlled devices. I had a network outage once where I had to access the device inside the LAN but InControl had set the password and I didn’t know it. You can specify the password for devices to a known and specified password but it isn’t the default setting for InControl.
So the device is out of warranty. :slightly_frowning_face:
Any ideas on how I can console into the device, like a back door
Hi @luper11,
If the device is within Warranty and the InControl settings on the GUI are still at their default, then yes, the device should report to InControl - as long as it has a working WAN connection.
Where InControl is managing the password, you can use InControl to find this password - see below:-
I hope this helps,
Steve
Unfortunately, the device is out of warranty. :worried:
Is there a back door to accessing the device physically using a console or something …?
Unfortunately not, sorry - if the warranty has expired then it stops reporting to InControl.
You can try different ports to access via the LAN - the default ports are 80 and 443 (but you may have changed these to something different).
Sorry,
Steve
You could also factory reset the device of course by holding in the reset button for a 20 count. Brutal fix and Steves idea is more elegant but hard factory reset would work.
