Hello Peplink team. I have a Balance One Router and currently 2 AP One’s. This house has too many brick walls to only have one AP.
I set the Router to 192.168.50.1. I set the First AP One to 192.168.20.1.
I thought this would help separate the networks. It is very important the the untagged LAN and the IOT and guest network to not be able to communicate. All business must be accomplished via a wired network or VPN.
At one time I was able to connect to the AP One, but there was way to much latency switching between the Router and the AP One signals. So I have been making changes to the router and testing one change at a time.
I changed the Management VLAN ID from the untagged LAN to the IOT VLAN. When I connected the Balance One with my phone it assigned a 192.168.20.x number. I thought great. Maybe that will decrease the latency and separate the business network from the IOT network better.
Now I can only wirelessly connect a wifi device–phone–to the the Balance One Router. I changed the Management VLAN ID back to the untagged LAN, but I still cannot connect my phone to the AP one device.
Below is part of the event log, one for each AP mini
|Dec 14 14:19:18|2932-C2F2-AEA3: Client DC:EF:CA:5C:ED:6D disassociated from Tinman|
|Dec 14 14:18:41|2932-C2F2-AEA3: Client DC:EF:CA:5C:ED:6D associated with Tinman|
|Dec 14 14:18:41|2932-C2F2-AEA3: Client DC:EF:CA:5C:ED:6D disassociated from Tinman|
|Dec 14 11:17:42|192C-2DE8-8CF9: Client 00:D0:2D:C9:01:08 disassociated from IOT|
|Dec 14 11:17:42|192C-2DE8-8CF9: Client 00:D0:2D:C9:01:08 associated with IOT|
|Dec 14 11:16:44|2932-B35A-7527: Configuration synchronized and applied|
These are my current settings:
Balance One Router
VLAN settings:
- Untagged VLAN: LAN
- “IOT” VLAN: 8
- “Tinman” (guest) VLAN:7
Defined SSIDs:
SSID_LAN (Assigned to LAN)
SSID_IOT (Assigned to VLAN 8)
SSID_Tinman (Guest) (Assigned to VLAN 8)
Physical interfaces:
LAN8 - Port access IOT------>Unmanaged Switch---->AP One AC Mini:SSID_IOT (VLAN ID 1),
TV, Receiver, ROKU, Computer,etc.
LAN7 - Nothing
LAN6---->Unmanaged switch---->Server, business computer in another room
LAN1-5---->computers, printer
AP One AC Mini:
SSID_LAN (VLAN ID 0) Turned off
SSID_IOT (VLAN ID 8)
SSID_“Tinman” (guest) VLAN:7
Thank-you
