What is the MAX-BR1’s embedded 3G max Tx power and Rx sensitivity?
tnx
tnx
The TX power and the Receive sensitivity of BR1’s embedded 3G module (HSDPA/HSUPA mode) is around 24dBm and -109dBm respectively.
Antony
Thanks Antony. How about the one embedded in MAX-HD2?
The embedded 3G module embedded in MAX-HD2 is as same as the one used in BR1-3G. The TX and RX spec are the same.
Antony
Thanks Anthony. How about the embedded 4G modem for BR1 and HD2
The TX power and the Receive sensitivity of BR1/HD2’s embedded 4G LTE module (4G LTE mode) is around 22dBm and -102.5dBm respectively.
Antony
