I have two unrelated feature requests:
- This one may seem odd, and it only would work on the present product line if the USB port supports connecting to USB devices through USB hubs if one needs to support this plus USB modem fallback. But I’d like to see support added for hardware keys like Yubikey’s. Discover YubiKeys | Strong Two-Factor Authentication for Secure Login
In other words, require a hardware token to be plugged into the router’s USB port in order to login for administration purposes. It would be a cheap way to add another level of security. Whether admins leave the token plugged in all of the time, or don’t, is their business. But it might be one way of requiring the admin mucking with the router to be physically at the router’s location. Which might be valuable for some people. It certainly would be a unique feature, as near as I can tell.
Anyway, worth thinking about.
- The other request, which would be of use to me now, is to extend the “Internal Network Firewall Rules” (Advanced –> Firewall –> Access Rules) to NOT be limited to transitions between VLANS. Right now, these rules only seem to be active for internal traffic between VLANS. I would like to see these rules also be enforced (or allow it optionally be enforced with a checkbox?) between devices on the same VLAN.
