I am interested in isolating IoT devices as much as possible on their own WiFi network. How many different SSIDs can a Peplink AP create?
I tried to find this in the latest manual but it does not seem to be documented.
Also, as part of the security, I would like to limit the number of devices on a given SSID. The manual is not clear about this. On page 28 its says to “Enter the maximum number of clients that can simultaneously connect to your access point”. Can you please verify that this is a mistake and that the field in question is really a limit for one given SSID.
It appears to be a mistake not only because it is in the SSID properties section but also because there is a similar field for the maximum number of clients on page 37 and that one does appear to be for the entire AP.
Thank you.
