Back in February, we rolled out two 2.5G PoE Switches - and now, we’re introducing two powerful new additions!
24 PoE 2.5G Switch Rugged – Built tough for harsh environments, this switch comes with a wider operating temperature range and a fanless heatsink design to keep things cool and quiet. Plus, with redundant power options, you won’t have to worry about power failures messing with your setup.
8 PoE 10G Switch – Need blazing-fast speeds? This one’s for you! With 10G PoE++ ports, it crushes bottlenecks, boosts data transfer speeds, and keeps your high-performance network running smoothly - whether you’re handling enterprise workloads, high-end computing, or ultra-fast connectivity.
Ready to take your network to the next level? Check them out now!
