Hi! Corporate customers request this. Can you say that we support this since Radius can be used to authenticate users for admin? The “two step” is what I do not know. At first, customers requested access using a token (like RSI) like those when going to bank sites.
Are you referring to local Web Admin (login to the device locally) with Two-Factor Authentication? If so, this is not supported.
Two-Factor Authentication is supported in InControl2 (if the customer uses InControl2 to manage their devices).
Thanks TK for your answer. We are now using two factor a. when using IC2. Works fine with google authenticator.
