Tweaking of Reports
Goodmorning to all,
i would like to suggest a new option
i think it will be great if we can change the reports we can send out.
on this moment there are only basic reports , with some data that has no value for us
i think it would be great if we can select topics to add to a report to send.
We for example would like to send a daily wifi report to our captians with the data used on board
but on the second page or second report we would like to send the daily report + 1
so for example the data from august 1 + data from August 2) etc etc etc
+1 From here
The automated reports come in PDF format (as you may have discovered) and not CSV.
It would be great to have report emailing done in a custom format, and custom output - so worth putting into a Feature Request! If I have missed this as an option, I hope someone will correct me!
