I put peplink in my home instead of ubiquiti or eero. I love it. But the blue led lights are bright when watching tv. Is there a way to turn them off?
I don’t think there is a way to do this via InControl2, however if you log into the AP GUI you can disable the LEDs entirely.
You can also add a sheduled Task to switch off the LED in the night/evening
BR
Thank you both!
I would also like to disable the LEDs on an AP One AX Lite - I do not see the LED option on the web log in. I am using 8.4.1 firmware on the BR1 Max.
I was thinking about this the other day, think we need a feature request.
Being able to manage and see the status of the LED of an AP for IC2
Want to be able to define it by a tag too
Yes - I agree, this would be very useful Adam.
Thanks Captain_Nik very helpful!
I had wrongly assumed every AP setting would be available via IC or Web Admin for the BR.
You are most welcome - your question did raise a few of us to poke Peplink if maybe now is the right time to add this to IC2 as well.
