changed the device IP to 10.57.20.11 (Balance 20 is 10.57.20.10)
disabled DHCP on all networks
unplugged WAN cable
WIFI configuration and other configurations left untouched.
I connected a LAN port from the SOHO (ACCESS port type) to Lan port 4 (TRUNK) on the Balance 20.
I’m uncertain on whether i should be setting lan port 4 on the B20 to Trunk, but based on my understanding, if the device connected is capable of tagging, like the Surf SOHO, then TRUNK is proper.
For some reason, I’m not seeing the SURF SOHO as a client on the B20 client list even though i can connect to it and created a dhcp reservation for it.
FYI… was hoping i could test out Bonjour forwarding by setting a LAN port on the SOHO AP to “ACCESS > My IoT VLAN”… but the apple device can’t connect (Airport Express used for audio streaming)
Not sure if this is feasble… figured setting up the port on the SOHO to ACCESS > vlan ID 21, and SOHO connecting to B20 via lan trunk port, the B20 would pick it up.
I’m going to try something similar in a few days. I’ve been wondering if I should plug the wan into the lan, so that it gets an IP on both interfaces and can talk to the internet.
Still, it seems a missed opportunity not to have an AP mode, or a bridged mode so that wan and lan are the same.
Yeah its a little frustrating. Right now i have wifi working over main untagged lan, but my vlan wifi ain’t working. It doesnt seem to be assigning IPs so no devices are connecting (wired or wireless)
Having it offline in inControl is not a showstopper, as I’ll probably stop using inControl.
So, problem why vlans were not working? I hadn’t enabled “trunk” on the lan port of the SOHO connected to the B20.
Makes sense, the SOHO being in “access” mode, was sending down packets untagged IPs, so B20 was serving them from the untagged lan… IPs no longer matched, so no dhcp assignment.
So in this case, important to have “trunk” enabled at BOTH ENDS.
Regarding the time sync on the SOHO. Saw an option on the Balance 20 to enable NTP server. Checked that off, then used my Balance 20 IP as the Time Sync server on the SOHO.
