Gentlemen of the forum, I wanted to validate with you if the capacity of the speedfusion tunnel in a Balance is the full capacity that is divided by each tunnel that is configured, or is it the capacity that each tunnel has according to what is indicated in the datasheet?
For example: The SDX PRO equipment indicates a PepVPN / SpeedFusion Throughput 256-bit AES: 600 Mbps, are these 600Mbps the total to be divided by each tunnel or is it the full capacity of each one?
Hi Juan,
the tunnel throughput is limited by the CPU, not by software. So in your example it is 600Mbps for all tunnels together.
