I am trying to connect to the BlueSky solar charge controller UCM (Universal Communication Module), via a Surf SOHO, so I can see the UCM web site on my Win 10 PC.
From the UCM manual:
Refer to the router’s documentation regarding communication setup for fixed IP Address devices. However, many
routers require two things be changed,
- Change the UCM’s IP Address to be within the IP Address range the router can assign via DCHP, and
- Add the new UCM IP Address to the routers DCHP Reservation list to reserve the UCM’s new IP Address for exclusive use by the UCM.
I can’t quite figure out how to do this with the Surf SOHO. I first tried to change the DHCP range, but I wasn’t sure what range to use that would be appropriate, and the one thing I tried gave an error message.
The IP that I’m trying to get to is http://192.168.1.235/
The current Surf SOHO DHCP range is 192.168.50.10 - 192.168.50.250.
