Troubleshooting - Speedtest and cell site survey not working
Has anyone else experienced issues running speed tests or cell site surveys in IC2? They simply will not execute despite saying the test has begun. Note, I have tested this on two separate B One 5G devices both on firmware 8.5.4 which support the cellular site survey feature. When running a cellular site survey, I have a survey schedule setup, which I run manually on a group with just the device I want to survey with in it, but the only way I can get it to run is by scheduling the test to run every 5 minutes and then turning it off after.
When running speed tests, I run ‘speed test - cell’ from the device level view, but I never get a report afterwards in my connection test reports tab.
Also worth noting is that there have been no group or device config changes, yet I was able to run these tests in the past with no problem.
Am I running into some kind of memory limitation on the device itself? I’m wondering if I have run too many tests and ran out of some cache on the device itself.
Self resolved -
While I am not entirely sure the source of the error, updating my cell modem firmware (not device OS), and making a new tag associated with the cell survey seems to have resolved this issue in case anyone else is running into something similar.
