Dear Support,
Can you please advice us on how to troubleshoot Speedfusion connectivity problems?
Charris Lappas
Dear Support,
Charris Lappas
Hi Charris,
Could you please elaborate more specific on your request, as in which area of connectivity problems? Is it related to SpeedFusion Link Failure Detection, or other layer 1 or layer 2 issues?
We would need more details in order to provide the appropriate response.
Thanks and regard.
Hi WeiMing,
We are interested to troubleshoot issues during the creation of the speedfusion, problems like a) Incorrect Remote IP address of the other site, B) Incorrect Remote ID or pre-shared key.
Charris Lappas
Hi Charris,
Before deployment
After SpeedFusion/PepVPN was configured
You will noticed stages below once you have configured SpeedFusion/PepVPN profile:
I am running V6.3.0 and was using a guide on setting up L2 Speedfusion. It has been stuck at starting⦠and refuses to go to the next step. I can ping IPs on the internet but can not ping each other. I can also ping these modems from my office corporate connection. Could this be a carrier issue?
Hello @jruiz,
You may have already checked though it is worth another look at your connections between your Peplink/MAX routers and the outward bound network connections that they are not blocking the required Port#s, this includes checking with your ISP/Carrier, many ISPs/Carriers block higher level ports now in an attempt reduce the usage of P2P transfers (such as bit torrent transfers).
Also we highly recomed that you upgrade the Peplink/MAX devices to the latest firmware also.
In addition please let us know if you are using InControl2 to build & manage your SpeedFusion or settiing it up directly on your devices, we recommend building SpeedFusion using InControl2 over doing it directly within the devices especially for first timers
See how you go with this and let us know.
Happy to Help,
Marcus ![]()
@mldowling
My devices had sequential static IPās and one had the otherās IP as a gateway. I could ping any public IP but could not ping one another. I ran a quick trace route (from one to the other) and saw that only one modem was actually getting out to the internet. The other one was not even getting to the first router - this is the one that had the otherās IP set as its gateway. Apparently these devices calculate their own network and gateway from the provided carrier IP address. The fix for this is to change the Subnet Selection to Force/31 Subnet in the WAN connection Settings tab. I had help from our vendor on this issue, and he said it was fairly common when getting sequential IPās. Hope this make sense.
Hello @jruiz,
Thatās great news and good to know about too.
You are welcome to give credit to your vendor here for getting you sorted, who are they?
Happy to Help,
Marcus ![]()
@mldowling
Our wirelss modem vendor is Industrial Networking Solutions form Addison, TX. They were the ones that actually recommended this modem for this purpose.
Iām having another weird issues with the L2 tunnel, that I just emailed them about. I was running the VPN in untagged mode and some devices were just not wanting to work. After some Wireshark captures I saw that the tunnel was adding a VLAN 0 tag with a priority of 0 to the packets. Some devices do not like that and will not acknowledge the ARP request/reply or pings. I searched this site and could not find anyone with a similiar problem, or maybe I just wasnāt searching for the right key words.
Juan
@jruiz Found you had opened a support ticket for the same issue.
I would suggest the following:
Make sure the VLAN0 is not added by the switch that direct connect to the Peplink/MAX devices (If there is a switch involved for the deployment)
Please upgrade the device using the latest firmware to isolate the old firmware 6.3.0 issue.
You can download the latest firmware by using the following URL:
After upgrade the device using latest firmware and you still found the issue, please continue work on the created ticket.
My devices are a max hd2 and a 1350. I have them on a bench connected via their wan ports. All other connections are disabled.
I have a router with one interface on 10.10.100.1 and max hd at 10.10.100.2. the 1350 is on another interface as 172.16.1.1 for the router and 172.16.1.2 for the 1350. all /24
Router has no other config other than interfaces
I can ping the devices from each other from the WAN. I have set up tunnels both ipsec and speed fusion and neither one will connect.
I have gone over every video and config guide I can find. How do I troubleshoot where the problem is?
I never get to authenticate
There is no info in logs on either device
Greetings!
At the " Startingā¦" phase, is UDP used, and what source and destination ports are used?
We have UDP4500 and ICMP open between two Peplinks, but the tunnel doesnāt establish (the IP addresses are reachable by PING.)
Dana
TCP 32015 is used as the āhandshakeā and is needed to establish the tunnel. Thanks
