What is the best way to set up an AP One Mini (v3.7.0) with a Pepwave SOHO MK3 (v8.0.1)?
I am having an issue in certain areas of my house where I lose my internet connection even though I am still connected to my WiFi network. I am using the same SSID and password for the Mini and SOHO. My hack-y workaround has been to turn off WiFi on my device (i.e. iPhone) for a few seconds and turn it back on. After a few tries, I am able to get connection to the internet again.
I am using the web interface with these settings:
AP One Mini:
Operating Mode
Bridge Mode
WAN Settings:
DHCP
Routing Mode: NAT
DNS Servers: (Points to my SOHO IP address)
Please forgive the newbie-ish question as I’m not much of an expert when it comes to networking. Thanks in advance.
To add to this, using a simple WiFi test app (Net Analyzer on iOS) I can see the handoff occurring promptly between the SOHO and AP. It takes minutes though (w/o user intervention) before I get an IP address and can ping the router.
I have the same hardware (AP One Mini connected to Surf SOHO mk3 over powerline ethernet), with same configuration and I have the same problem: when moving my iphone, ipad or macbook pro it takes about 2 minutes to re-establish internet connectivity when joining the AP One. I will be interested in the response from support.
We confirmed that issue would happen on Soho MK3 when there are any of its LAN ports configured as Access Port. We are working on the fix.
Meanwhile, the issue could be avoided by configuring all Soho MK3’s LAN ports as Trunk-Any.
Thanks for the workaround, which does solve my wifi roaming problem with the AP one mini. Please let me know when the fix is available for the SURF SOHO, as I would like to re-establish my port-based VLANs in the router.
I am posting this in hopes it may help others using the Surf Soho MK3 who have wifi handoff issues.
My Pepwave Soho MK3 serves as both a router and an AP. I also have a Pepwave AP One Rugged (for coverage in a different part of the building) which just relays IP addresses from the Soho (which serves as the DHCP server).
Without a VLAN enabled and port assigned as “access”, the iOS devices handoff between APs perfectly upon leaving signal range. However, with a VLAN enabled and port assigned as “access”, the iOS devices that go out of range of the Soho will connect to the Rugged AP but drop the DHCP relayed IP address. The iOS device will then self-assign an internal IP number (i.e. 169.254.xxx.xxx) about 6 times over the course of ten minutes before finally obtaining its correct original IP address relayed from the Soho DHCP server through the AP One Rugged, once again establishing network/internet access.
The workaround for this issue is to disable VLANs with ports assigned as “access” (it’s possible that ports assigned as “trunk” may be OK).
The actual fix is available in beta firmware 8.0.2s005, and Pepwave support messaged me today that it will be included in the next G.A. firmware.
Thought this would be the silver bullet I was looking for but unfortunately not. Have the same symptoms so I switched all my ports to Trunk on the Surf Soho MK3 but no luck.
I have seen iPhones refuse to connect to multiple SSIDs with the same name as part of their rogue AP detection. You might want to “reset network settings” on the iPhone and re-enter the SSID and password to give it a fresh start.
Also turn “Ask to join known networks” under the iPhone’s WiFi settings to off so it connects automatically. Do the same for “Ask to join hotspots”?
I have also seen iPhones (iPhone 8, iOS ~13) flat out refuse to connect to open SSIDs even after having previously connected to them. Avoid using an open network for the Guest AP?
On the AP one mini enable “fast transition” under security settings. Try setting the “Client Signal Strength Threshold” on the AP one mini and SURF SOHO to 20 or 30 (-75dbm to -65dbm) to encourage client devices to connect to the closest AP.
There is also a possibility that the SOHO or the AP one mini is running out of DHCP leases. Set the lease time to 2 mins and wait for 5 mins to clear them all out and then set it to 1 day.
Check the AP one mini Status>Rogue AP for anything suspicious.
