We have recently had some difficulty to integrate our Peplink solution into a network. Our current Network setup is as follows in brief. We have two WAN links. WAN link 1 has a network address of 41.0.73.34/27 and WAN link 2 has a network address of 41.160.17.2/27. The LAN side with an IP of 196.41.196.33/24 is connected to a Cisco PIX firewall. Between the Peplink and the PIX we want to perform IP forwarding. From the PIX we want to use NAT to a server with an IP of 10.100.10/24 behind the PIX. When we try to create the second NAT rule the PIX display’s ‘ERROR: duplicate of existing static’.
Hi there,
The Best way to approach this issue would be to create a service ticket and send into us a diagnostic report while the issue is occurring along with a network diagram with your IP’s listed for review.
Instructions on capturing the report can be found at the following link-
You can create the ticket and send in everything at the following link-
http://www.peplink.com/contact/support/
Once everything is turned in, we can review the information and figure out the best way to proceed.
Thank you for your patience in this matter.
Best Regards,
Jason
The Peplink Team
