Transit Pro E
The long-beloved Transit series is now introducing an Evolution!
It has more Ethernet ports to connect your devices.
It offers PoE+ output to reduce cable clutter.
It works as an Edge compute engine that processes data close to the source for faster, safer insights.
And it gives you greater flexibility with its eSIM support.
It is perfect for critical operations like emergency response.
Introducing the Transit Pro E - a rugged, mobile 5G router that takes your connectivity to the next level.
