Does the Transit work with HotSpotSystem as found on HotSpotSystem.com ?
If so what is the process to get that setup?
HotSpotSystem Wi-Fi on Pepwave MAX Routers is the scheduled feature for device firmware 6.3.2 (Currently in Beta version).
You can refer to Peplink knowledge-base for the setup guide:
http://www.peplink.com/knowledgebase/using-hotspotsystem-wi-fi-on-pepwave-max/
Thank You
