Hi
I’m wanting to use the Mobility 42G antenna with a Transit Duo to give me 2x2 MIMO antennas.
2 questions:
- The Transit Duo has 4 cell connectors: a Main and Diversity/ Aux for each radio. The Mobility 4G has 4 LTE connectors labeled 1 - 4. I can’t find anything in the data sheet and I’m wondering what should I connect to what for best performance?
- I’ve also noticed in the data sheet that the gain is much better with a ground plane (see attached). Is there a recommended minimum size for a ground plane?
David
