Too much traffic causes modem to offline
I have a peplink Max BR1 and I have some devices sending data over the cellular connection of it. I then added 5 cameras to that network and sent that video feed over cellular as well.
This caused the modem to go offline. That tells me it was too much traffic for it. All devices are on the same Lan, would it not go offline if the cameras are in a different LAN?
Quick questions to get us started:
  1. Which MAX BR1, please? There are many. Mini LTE with CAT4 modem? Pro 5G?
  2. “I added 5 cameras to that network …” You added 5 cameras to the LAN in addition to other devices? Right? What else is on the LAN-side?
  3. Please define “offline.”
  4. What was the required throughput to upload all data from all devices on your LAN? In particular, what do the cameras require at the resolution for which they are set?
  5. When you perform a test, what speeds are you seeing with only the test computer attached to the LAN? Up/down/latency/jitter?
