TOGETHER SY : Fast Internet connectivity fitted by SeaSatCom
SeaSatCom : Your Internet and AV provider, making easier your life on board
15 years of experience, 155 yachts trust us,
  • Owner was requiring a strong internet connectivity in order to continue working while on board,
  • As a sailing wessel, the choice was to install the 4G antennas and the modem on the 1st spreader avoiding signal loss, So the HD1 Dome became obvious together with a PoE switch and AP Entreprise for guests wireless connection.
Benefits
  • Speedy internet due to the LTE-A Pro modem embeded on the HD1 Dome,
  • Wireless connectivity for the guests all accross the vessel.
“Searching for an efficient 4G internet connectivity, I have contacted SeaSatCom which has proposed me a turnkey solution matched with TOGETHER SY.
As Peplink Certified  Partner, they proposed the LTEA Pro (1.2 Gbps) Dome  including in one enclosure modem, antenna, router etc with just one POE ethernet cable from the first spreader to the vessel.
Do not hesitate to contact SeaSatCom if needed. They have helped me => they are going to help you !”
Yann Lefebvre
