Our end user is requesting to access peplink to check the Active Client. Is there any way to give our end user read only access andwithout seeing other feature like “Event log,Speedfusion…” only active client list?
It possible to give end users read only access however they will be able to see Dashboard and Status tab information. You can enable/create a read only username in the Balance itself under the system tab. Or if using InControl2, you can also grant them read-only access as well.
