Almost like clockwork, each night I lose my internet connection. After looking through my logs, I see a time synchronization failed message around the same time I lose my connections. Here is a sample.
Preformatted text Device Event Log Apr 28 10:20:16 Admin: MooLAeFdi (192.168.29.11) login successful Apr 27 23:54:08 System: Time synchronization successful Dec 31 19:02:06 System: Wi-Fi AP Normal Mode Dec 31 19:01:41 WAN: WAN connected (**********) Dec 31 19:01:13 Web blocking: Activated Dec 31 19:01:01 Port: Port 2 status changed (link up, speed 100 Mbps Full Duplex) Dec 31 19:00:57 System: Started up (7.1.2 build 1387) Apr 27 23:07:37 System: Time synchronization successful Apr 27 22:50:11 Admin: MooLAeFdi (192.168.29.11) logout Apr 27 22:41:17 System: Changes applied Apr 27 22:39:20 System: Changes applied Apr 27 22:38:10 Admin: MooLAeFdi (192.168.29.11) login successful Apr 27 22:15:06 System: Time synchronization fail Apr 26 22:40:38 Admin: admin (192.168.29.11) logout Apr 26 22:40:08 System: Changes applied Apr 26 22:36:41 System: Changes applied Apr 26 22:35:20 System: Changes applied Apr 26 22:33:19 Admin: admin (192.168.29.11) login successful Apr 26 22:33:09 Admin: MooLAeFdi (192.168.29.11) login failed Apr 26 22:32:39 Admin: MooLAeFdi (192.168.29.11) login failed Apr 26 22:32:24 Admin: MooLaeFdi (192.168.29.11) login failed Apr 26 22:31:09 System: Time synchronization successful Dec 31 19:02:03 System: Wi-Fi AP Normal Mode Dec 31 19:01:34 WAN: WAN connected (98.166.81.112) Dec 31 19:01:09 Web blocking: Activated Dec 31 19:00:57 Port: Port 2 status changed (link up, speed 100 Mbps Full Duplex) Dec 31 19:00:52 System: Started up (7.1.2 build 1387) Apr 26 22:27:14 System: Changes applied Apr 26 20:43:22 Port: Port 2 status changed (link up, speed 100 Mbps Full Duplex) Apr 26 20:35:04 Port: Port 2 status changed (link down) Apr 26 20:32:49 Port: Port 2 status changed (link up, speed 100 Mbps Full Duplex) Apr 26 20:22:09 Port: Port 2 status changed (link down) Apr 26 19:26:49 System: Time synchronization fail Apr 26 18:22:04 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=108.178.16.154 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=54321 PROTO=TCP SPT=56785 DPT=443 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 18:14:45 Admin: MooLAeFdi (192.168.29.11) logout Apr 26 18:13:40 Admin: MooLAeFdi (192.168.29.11) login successful Apr 26 16:45:03 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=216.243.31.2 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=54321 PROTO=TCP SPT=52728 DPT=443 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 15:27:32 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=185.173.35.21 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=35517 PROTO=TCP SPT=65154 DPT=443 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 14:07:21 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=185.53.88.157 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=41627 PROTO=TCP SPT=56356 DPT=443 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 13:31:34 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=185.5.64.120 DST=192.168.29.200 LEN=48 TOS=0x00 PREC=0x00 TTL=252 ID=1717 PROTO=TCP SPT=64697 DPT=443 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 09:11:45 Admin: MooLAeFdi (192.168.29.11) logout Apr 26 09:09:39 WAN: WAN changes applied Apr 26 08:58:19 Admin: MooLAeFdi (192.168.29.11) login successful Apr 26 08:53:55 System: Time synchronization successful Dec 31 19:02:04 System: Wi-Fi AP Normal Mode Dec 31 19:01:37 WAN: WAN connected (********) Dec 31 19:01:10 Web blocking: Activated Dec 31 19:00:57 Port: Port 2 status changed (link up, speed 100 Mbps Full Duplex) Dec 31 19:00:53 System: Started up (7.1.2 build 1387) Apr 26 07:40:38 Port: Port 2 status changed (link up, speed 100 Mbps Full Duplex) Apr 26 07:32:39 Port: Port 2 status changed (link down) Apr 26 07:15:23 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=185.234.217.42 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=27720 PROTO=TCP SPT=58018 DPT=443 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 05:13:10 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=45.79.106.170 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=54321 PROTO=TCP SPT=41329 DPT=443 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 03:30:54 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=125.64.94.210 DST=192.168.29.200 LEN=60 TOS=0x00 PREC=0x00 TTL=252 ID=61559 DF PROTO=TCP SPT=51968 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 03:28:14 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=125.64.94.210 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=54321 PROTO=TCP SPT=46428 DPT=443 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 00:28:16 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=104.152.52.25 DST=192.168.29.200 LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=41331 PROTO=TCP SPT=51707 DPT=443 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0xa Apr 26 00:14:13 Allowed CONN=WAN1 MAC=00:1a:dd:43:40:81:84:8a:8d:32:cc:19:08:00 SRC=108.178.16.154 DST=192.168.29.200 LEN=60 TOS=0x00 PREC=0x00 TTL=252 ID=24243 DF PROTO=TCP SPT=58804 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0 MARK=0xa
What can I do to fix this?
