Just installed Surf SOHO router. Speed check shows 235mbps coming from cable modem. SOHO is wired directly to modem. Hardwired connections from SOHO are less than 100mbps. Wireless is about the same. All Ethernet runs are less than 6 feet. And suggestions?
Hi Harold
I’ve tripped over similar issues. Firstly the Soho is rated at 120Mps. Many of us are used to way more than this from our devices in today’s high bandwidth.
Secondly, if you’re using other features, the actual throughput will drop further, especially once you start using SpeedFusion and/or encrypting traffic.
Hope that helps
David
