Three Network SIM connecting on one pepwave but not another
I have a Three network SIM that works on the below:
Model
Pepwave MAX HD2
Product Code
MAX-HD2-LTE-E
Hardware Revision
5
Serial Number
2934-B697-DA93
Firmware
8.4.0 build 5595
SpeedFusion VPN Version
9.2.1
But with the same APN settings, does not work on the below. Just stuck on obtaining IP address
Model
Peplink MAX HD4 MBX
Product Code
MAX-HD4-MBX-5GN
Hardware Revision
4
Serial Number
1931-3185-2AEF
Firmware
8.4.0 build 5736
9.2.1
It seems to see the SIM and find the correct APN but just won’t get past obtaining ip address. Other 02/Voda sims in the device work fine.
Any ideas?
