Hi, I have 80 users in my office and I want a cost effective solution to balance my 2 isp (1 is 4 Mbps, the other 10 Mbps) . I’m a little worried about the product sizing recommendation (1-25) users. I don’t want the router to be blocking or performing badly.
Any comments on this I would appreciate it.
The number of users is for sizing purposes - there is no software limitation at all.
I will look at 1) the number of Ethernet WAN links, 2) their total upstream and downstream throughput and 3) supported features, to pick the right model.
Thanks, I know there’s no sw limitation on the number of users, my concern was more about the difference in cpu/memory between models, and though the probable impact of that on the network performance.
