@Noah_Helterbrand you should be able to login with your Peplink ID on https://ticket.peplink.com if you are a partner. There you can create tickets directly, which will reach Peplink Support directly.
Not sure if it might be different in other regions, but for EU it works great for us.
Yes, I can login and create tickets without issue, and I do periodically for fusionhub/IC2 issue. However in this case because it is a hardware device, peplink’s policy seems to be that I can only go through our distributor for support, even as a partner.
Trust me I’ve tried. I found out about it because I opened a ticket and just got “sorry, you must go through your distributor for support.”
If that policy has changed recently, then I haven’t received any notices about it.
For any issues related to product/firmware/hardware, we are always welcome to work direct with our valuable customer/partner. This is to make sure we have the faster response time to identify and resolve the reported issues.
I have created a ticket for the above and let us work from there. This will allow us more easy to look at the reported issues.
We are hitting the same roadblock, i would want to prevent us to revert to a different brand. How soon do you think a update will be shared about a timeline.
I know you most prob wont have a answer to this, however i want to prevent a redesign in our case as much as possible.
I don’t understand what you mean. Are you saying that I can now (as a partner) bypass our distributor and work directly with peplink on hardware and firmware issues?
I appreciate the ticket opened. These switches are carrying critical connections and we are restricted from making config changes or performing testing outside of specific windows and without the vendor on the phone with us while configuration/testing is being performed. Before I proceed with your ticket, will you be able to provide contact information so that we can schedule a time with the client to be able to work on the issues in real time to meet their requirements?
Thank you Christopher for correcting my typo error .
Yes , it’s IGMP snooping option !!!
I’m not sure why I was typing it as SNMP … Potentially I’m testing the SNMP feature while replying the post and this cause my hand & my mind are not in synced
It seems Peplink forgot to include that feature in the new firmware. We attempted to redirect the new switches from our cloud-based InControl 2 instance to a private ICVA instance via configuration, but that didn’t work either.
The situation is even more frustrating when you realize that the local switch controller doesn’t allow VLAN creation without first adding a network to the switch controller device. In their current state, the switches are barely usable as real switches. For example, I have another switch forwarding a VLAN-tagged packet to a device connected to my Peplink switch, but due to the limitations mentioned above, I’m unable to use that device properly.
Peplink should urgently address these issues—either by adding support for managing the switches through an ICVA instance or by enabling VLAN creation without requiring a network to be defined on their switch controllers.
