i have yacht in Egypt and there are some problems with Internet. The friend of mine had recomended me Peplink products, and i have some questions.
as far as i understood from my friend’s explanation - i can put several 3G modems and will get aggregated chanel.
For example - 1 Vodafone modem, 1 Etisalat, and some other.
There are no LTE in Egypt.
We are doing link load balancing. You can leverage on our technology - SpeedFusion Bonding, if bonding is required. Please refer here for better understanding.
Will Peplink products work in Egypt in 3G?
Yes.
If YES - which equipment will suit my purpose?
You may consider Max700 if 3 modems are required.
Max-OTG is more suitable for mobile user and Max700 is designed for harsh environment. This is the reason I proposed Max700.
HD2/HD4 came with embeded cellular modem. Therefore they have different models to support different carriers in world wide. However Max700 and Max-OTG are depending on the attached USB modem for the supported carriers.
