I am considering purchasing a Pepwave Surf On-The-Go device. The RV park I am at uses TengoInternet for the wifi/internet provider. This service is an open connect with a web signon using a provided userid/password. Will the Surf On-The-Go allow me to do a web signon after I have set it up and connected to TengoInternet?
We have the feature for captive portal login. Anyway, this is depending on how the ISP handles it.
You may contact our local partner on this request.
Thanks.
