We have a MAX-HD4 and we can see a nice temperature reading in the web interface but we are not able to find any documentation on how to access this info over SSH. We can use a lot of “get”-commands but it won’t take “get temperature” or “get temp”. Someone know if this is possible and in that case what’s the command?
Hi GuFe - welcome to the forum!
There isn’t a get temp command on the CLI that I’m aware of its not in the guide either.
You can get this using SNMP though and the custom MIBs.
Thanks for the answer, I couldn’t find anything in the SSH documentation either. It’s a shame that we can get a lot of info from the PEPLink router through SSH but not anything as simple as the temperature. Our application is build around gathering info over SSH from a lot of devices in the network where the router is just one. It would require quite a lot of effort to also implement a SNMP handler in our software, just to get the temperature. Anyone know how to post a feature request?
Have moved this to the feature requests section.
Thanks a lot! For us it’s fine to either have it as a separate command or included in the ‘get status’ response.
Best regards,
Gunnar
Request filed and Engineering team is considering the feasibility.
