To authorize outgoing <nnn> TCP and UDP port in firewall, must create two separates rules, or is it sufficent select -> “Protocol: IP” ?
ALex.
ALex.
Hi Alex, I would suggest that you create two separate rules for TCP and UDP port in Firewall. IP protocol numbers are different from TCP/UDP.
Thank you for suggestion.
ALex.
