hi i use a Peplink FusionHub and Max BR2 Pro
i upgrade them to 8.3 and the try to use TCP Ramp-up in the SpeedFusion config
but i didnot have that option
is this devices dont support it?
It’s only available with local config. Not sure when inControl2 will add support for it.
Thank you
How does this TCP Ramp-up work from a technical standpoint?
