I’m in the process of setting up a Surf Soho MK3 (Firmware 8.1.2s052 build 5022). The Surf Soho is connected to the LAN port of my existing router.
When I run nmap -Pn on the Soho, it shows that TCP ports 21, 554, and 7070 are open. I have not set up any port forwarding. How do I close these ports?
I new to setting up routers and any help would be greatly appreciated.
Hmm. That doesn’t show me the results I would expect.
I’m pretty sure something else is responding to the nmap scan on those ports.
Is there any device between the LAN of your existing router and the Peplink?
When you are connected with a cable to run the nmap, where are you physically plugging you laptop into? The LAN of the firewall or a switch on the LAN of the firewall?
