Question for the Peplink Community. Has anyone tested the Taoglas 5G antennas and had good results. I saw them yesterday and like their form factor. I was told they are a dramatic improvement over the antennas that come with the Peplink devices so I’m looking for some validation. Any thoughts you can share would be appreciated. Thx
I’ve had good luck with the 5G antennas.
Those green WiFi antennas bottle neck real easy.
There isn’t a real antenna inside them.
Thanks for sharing I just ordered some to test.
Just confirm what connector you need. For the BR1 Pro I used SMA and RPSMA however I also ordered Fakra forthe Sierra XR80 in the picture.
I am using the BR1 and BR 2 Pro
Currently, I’m using a BR one 5G, a BR2 5G and many B one 5G’s. I believe they have the same connector configuration
Peplink doesn’t use Fakra. Below is the list of connectors we are using:
- SMA female for LTE/Cellular (BR1 Pro 5G, BR2 Pro 5G, B One 5G, etc).
- RP-SMA female for Wi-Fi.
- QMA female for LTE/Cellular (MBX Mini, HD4 MBX).
- N-type female for certain outdoor router.
