Tailscale Client Connectivity Issues
Greetings and Happy Friday!
I have a question about a client device using Tailscale behind a Pepwave router on 8.4 firmware. Specifically, I cannot reach the client via Tailscale when on not the same network as the device. I didn’t have this issue using a different router, so I can only assume that despite Tailscale being quite adept at traversing whatever network it is on, there is something specific in the way the Peplink devices handle this.
Therefore, is there a specific configuration guide or instructions on what settings need to be made to the “firewall” in Peplink? I would assume some ports need to be opened, etc?
Thanks in Advance!
Nothing should be blocking tailscale clients if there is a default config on the Peplink.
Are you using additional firewall rules perhaps? Tailscale needs TCP 443 and UDP 41641 to be able to pass.
