System Error 443
On the Dashboard screen my unit is displaying “System Error 443”. Everything seems to be working properly though. I cannot locate anything documenting this error.
What does it mean?
-Balance 580 firmware version 6.2.1
Can you please upgrade the B580 using the latest firmware & verify whether the same issue will happen again ?
You can download the latest firmware by using the URL below:
Do open a support tickethere if you still encounter the same issue after the firmware upgrade.
Thank You
Firmware has been upgraded to 6.3.0 build 1601
Error is still present. Any idea what the description of this error is?
Possible to share the support ticket number here ? We may need to further investigate for the reported issue. Beside that, make sure you include the error message screenshot in the support ticket for us to further diagnose the issue.
Thank You
