I configured my Model:Peplink Balance 30 with Firmware:5.2.2 build 1108 to send syslog messages to my logserver.
But the peplink does not send anything ?!?
Remote Syslog Setup
Remote Syslog
Enable
Remote Syslog Host 172.30.30.3
Port: 514
Is this a bug ?
reagrds
Check if you can ping your syslog server from the Peplink’s LAN side .
Check the listening Syslog server port and the port configured on the Peplink device.
Tim_S
May 16, 2011, 7:16am
3
There is a known rare firmware bug with Syslog on that release. This will be fixed with version 5.3.5 which should be released in the next couple days.
Tim
Ah, glad I found this post.
I’ve just spent a few hours trying to work-out why the remote syslog functionality isn’t working on my Balance 30 (5.2.2/1108)…
Any update on the release of 5.3.5, the last post said “a couple of days” and that was a month ago
Oh, also when remote syslog works OK, what level of detail will i get? Is it more verbose that the internal event log?
Jason
June 23, 2011, 7:25am
6
Hi Ian,
I do see that you have opened a ticket with us on this issue and we will continue to work with you through that system.
Best Regards,
Jason
The Peplink Team
Hello Peplinkers,
what happend to “There is a known rare firmware bug with Syslog on that release. This will be fixed with version 5.3.5 which should be released in the next couple days.”.
This statement of Tim is now round about 2 month old.
regards
Tim_S
August 4, 2011, 2:37am
8
Hi Mario,
Please make sure your device is registered on our website so you can log in and always have access to the latest firmware releases.
Tim
Hi Tim,
these are the software versions which is presented to me as a registered device:
Peplink Balance Firmware 5
Date Posted Title Type Size Download
Jan 26 2011 Peplink Balance Firmware 5.2.2 for Balance 20/30 19MB
Mar 10 2011 Peplink Balance User Manual for Firmware 5.2 5.4MB
May 6 2011 Peplink Balance Firmware 5.1.5 for Balance 20/30 16.2MB
Sep 6 2010 Peplink Balance User Manual for Firmware 5.1 5.2MB
so there is no newer software !?!
regards
Peplink Balance 210/310 5.3.9 build 1032/1448
Bug Fixes:
• Unable to send syslog to LAN
Still does not work from vpn site-to-site.
e.g. 192.168.0.x send to 192.168.1.199
But from 192.168.0.x send to 192.168.0.199
.199 is log server
bhen.bh
November 2, 2012, 9:31pm
11
I recently bought the peplink 20, updated the firmware to 5.4.6 and i´m not able to change the syslog port number.
