I am switching from a MacOS server to a Synology DS1517+ and have setup its internal L2TP/IPSec VPN server.
I have setup all the required ports to forward from the NAS IP address to the WAN but still cant connet to the VPN.
I was able to pull up the build inn web server from outside the LAN so I am not completely dead in the water. But I am puzzled what I am missing here.
I was able to connect to the server using the Peplink VPN but I would like to use the Synology one. After this successfull test I removed the Peplink VPN settings to avoid a conflict.
Anyone else can share with me how they solved this?
Thanks!
Rogier
I would suggest to perform packet capture in Peplink device and make sure all the L2TP/IPSec traffics is forwarded to the Synology DS1517+.
Scooter, you have forwarded ports from the NAS to the WAN, but have not mentioned doing the reverse. When you initiate the VPN connection from a remote site the ports need to be forwarded inbound from the WAN to the NAS.
Network > Inbound Access > Servers to create identify the NAS LAN address
Network > Inbound Access > Services to specify which ports to forward
You’ll also need to open the same inbound ports in the Peplink firewall
Thanks, turns out by enablig UPnP and allowing the Synology create the ports it worked.
However I can’t see a thing what it did on the router. And after a restart lost the VPN agan andhad to run the UpnP “magic”. Not feeling very confinent in this setup.
