Synergy mode with SIM Injector
Yes, SIM-INJ-Mini is on 1.1.128 per the release notes.
Topology:
SC - LAN - SIM INJ MINI.
SC - WAN2 - SD. Yes, SC is enabled on WAN2 and WAN2 only.
SC is a MAX BR2 Pro
SD is a Transit Duo Pro E.
Synergy mode was working fine prior to upgrading to 8.4 beta. No configuration changes were made prior to or after the upgrade. I did try to factory reset the SD after upgrading to 8.4 beta, but that did not help or fix anything. Synergy mode works fine if I roll both back to 8.3.
Also the illustrious message, “RemoteSIM component is incompatible to the firmware, please contact distributor for support.” returns to the dashboard of the SC.
SC is a MAX BR2 Pro, SD is a Transit Duo Pro E, remote sim controller is a SIM Injector Mini.
Peplink Support has requested diagnostic reports. I’ll be sure to let everyone know what I find out.
