The OpenVPN license I purchased for my B One router works fine, but I noticed there are times when that remote (Proton) VPN server may have poor performance. So I created three OpenVPN profiles under Advanced>OpenVPN, but deactivating one and activating another is not reflected in the Dashboard after I hit “Apply Changes”. The only way I can activate the new profile is by uploading the desired .opvn file into the OpenVPN Profile section under Dashboard>OpenVPN Wan 1>OpenVPN Profile. Why is there no apparent linkage between the two? As such, the OpenVPN profiles under Advanced appear to be useless. Am I missing something?
@PearsonSailor ,
There are two different OpenVPN features available, each designed for different use cases. Please allow me to explain the differences below.
OpenVPN WAN (Dashboard > OpenVPN)
Documentation:
https://manual.peplink.com/documentation/peplink-b-one-series-user-manual/ch8-configuring-the-wan-interfaces/openvpn-wan/
This feature is typically used for the following scenarios:
- Device (OpenVPN WAN) → OpenVPN Server → Internet / Server Access
- Branch 1 (OpenVPN WAN) ↔ OpenVPN Server ↔ Branch 2 (OpenVPN WAN)
Key characteristics:
- Requires an OpenVPN WAN license.
- Provides more granular control through Outbound Policy and WAN Failover for the OpenVPN tunnel.
- Once the tunnel is established, it can function as a WAN connection and be used to route Internet traffic through the VPN.
OpenVPN (Advanced > OpenVPN | Site-to-Site)
Documentation:
https://manual.peplink.com/documentation/peplink-balance-and-mediafast-firmware-manual/ch12-network-tab/vpn/openvpn/
This feature is primarily intended for site-to-site VPN deployments, such as:
Branch 1 (OpenVPN) ↔ OpenVPN Server ↔ Branch 2 (OpenVPN)
Additional Notes
The examples above represent the most common deployment scenarios we currently see customers using for each feature. If your deployment requirements differ, or if there are any features or capabilities that are not currently supported by either OpenVPN WAN or OpenVPN (Site-to-Site) , please let us know. We would be happy to submit your feedback as a feature request for future consideration.
Thank you for your response. I am using the OpenVPN license as a client to build a tunnel for all my LAN devices behind my B One router (Scenario 1 in your response). So, based on your provided documentation, the OpenVPN profiles under “Advanced” are profiles for site-site OpenVPN tunnels only and have ni impact on client tunnels, correct?
OpenVPN WAN and OpenVPN (Site-to-Site) under Advanced are two separate features designed for different use cases. Therefore, their connection status and monitoring information are displayed on different pages within the Web Admin.
