SURF SOHO USB Wan Filter
I own a Pepwave SURF SOHO with hw version 1. Is there a way to filter devices that use usb wan when the ethernet wan fails? Would there be a way using Mac addresses or VLan?
yes, with an outbound policy you can use e.g. a VLAN to create this filter-roule.
Regards
Dennis
I’m not seeing a place to set the outbound policy. Are there pointers that can be given to make it appear? Screen shot of Network->WAN attached
The Surf SOHO does not have outbound policy rules because only a single WAN source can be active at any given time. It is designed to be a fail-over only device and does not support load balancing. Thanks
