Hello there,
I am new here as I am a proud owner of a Surf SOHO Mk3.
Unfortunately I ran into a dead end setting up my network so I am hoping the community can help me.
I am trying to setup multiple VLANs on a managed Switch (Netgear GS308T) connected to the Soho Mk3.
What I did:
Soho Mk3:
Setup Vlans 2,3,4,5 with their gateways (eg. 10.10.20.x, GW: 10.10.20.1)
Static IP for switch in untagged LAN
Netgear Switch:
Defined a Static IP with the gateway of the router
Setup same Vlans 2,3,4,5 (same vlan ID and PVID)
Assigned the switch ports to the vlans.
Vlan2,3,4,5: Port 1 (Tagged/Trunk Port)
vlan2: Port 1(tagged), Port 2,3,4 (untagged/access)
vlan3: Port 1(tagged), Port 5 (untagged/access)
vlan4: Port 1(tagged), Port 6 (untagged/access)
vlan5: Port 1(tagged), Port 7 (untagged/access)
Port 8: unassigned/dead
Soho Port 4 (Trunk, Any Vlan) connected to Switch Port 1 (tagged)
If I connect a Laptop to any of the Vlan Ports of the switch, I get the dedicated IP address assigned (10.10.20.X, 10.10.30.X, etc.) but I get no internet connection and I cannot ping the switch IP or the router gateway.
The Switch is not capable to route on its own. My best guess is, that the routing has an issue so my question:
How do I define the routing on the SOHO so that the switch knows that it should route all traffic through switch port 1 to the router port 4 and then to the WAN.
Your help is much appreciated!
Thank you,
Stefan_K06
