[Surf SOHO MK3] Remote access & RADIUS
Hi guys, I’m running a Surf SOHO MK3 on firmware 8.3.0.
I have configured the router’s remote user access fuctionality to use OpenVPN, this remote access works without issue. I would now like to provision an IP address for each remote user, such that users are given the same IP address every time they use the remote access service. It’s my understanding that using OpenVPN obfuscates the user’s MAC address and uses a random address each session, so in order to achieve the behaviour I want, I would like to use a RADIUS server.
Is this possible with the Surf SOHO MK3 on the 8.3.0 firmware? I have configured my RADIUS server via the router’s admin UI, but the only auth settings available for OpenVPN are the user credentials, nothing related to using a RADIUS server. Any help on achieving my desired outcome would be most appreciated, cheers in advance!
The Remote User Access for SOHO MK3 supports local authentication only. Radius authentication is considered an enterprise feature. You may consider Balance 310X if Radius authentication is mandatory.
