I’m a new user of this router, but even if I’m satisfied with all the features it offers, I’m having a problem after an update of my internet connection speed. I’m now at 90 Mb/s from my previous 18 Mb/s. I’ve always downloaded at 1.8 MB/s from my laptop (wifi connected), but now I’m stuck at that speed or little more !
If I use a cable to connect my laptop to the SOHO I get full speed and I get full speed even if I use the wifi of my ISP router! I
tried to do a factory reset, but nothing has changed. I’m using 2.4 Ghz band only (as the ISP router does) and the transmitting channel is free (I used a wifi analyser, but there are not many wifi networks around). WAN is the only gateway configured (no Wifi WANs); the signal is at -38 Db (optimal I would say) and I attached the 3 external antennas shipped with the router.
BTW How I can be sure the SOHO is using external antennas and not the internal one ? I couldn’t find any indication on the web admin.
If you look under the AP—>Settings there is an “Internal/External Antenna” setting with radio buttons. You can pick.
To be honest, SOHO WiFi performance is pretty poor. Even with external antenna. I’ve resolved to using a dedicated Ubiquiti access point if I need any real WiFi from these devices. For a simple use (maybe 1 or 2 devices for testing purposes) they are fine but nothing more. Pepwave sells several APs of their own but they get pretty poor reviews and I’m well versed with Ubiquiti stuff so I prefer those and just love their management stuff. Just some ideas. You may try a different external antenna (maybe a higher dB gain pair) but realistically you aren’t going to get very great WiFi performance on these particular routers themselves.
OK thanks for sharing your experience.
Before going out and grab a new access point I would be sure that the external antennas are used. Unfortunately my AP/Setting page doesn’t have any radio regarding antennas !
I’m sorry - you are using the newest MK3 - it does NOT have any internal antennas! So you are always using the external antennas. Mine are old HW1 model which do have the internal and I of course have that option to switch between the internal and external (if attached) antennas.
Yes, I tried some hours ago and I get full speed with one client only : 9 MB/s
I will share the wifi graph this evening (in Europe) and I will try to do some more tests on 2.4 Ghz band. If the router has the potential to serve data at that speed maybe we can find a way to fix the problem : the first test I want to do is to force the wifi channel on Surf once I got the one used by the previous router
Here’s the report at 2.4 Ghz and 5 Ghz The networks with erased name are mine. Later I’ll try to force the 2.4Ghz net on an different channel.
I used Wifi Analyser for Android. The phone was near the antennas of my PC and the transmit power of the Surf is set to low. I’ve already tried to maximize it, but the throughput doesn’t change
I had great WiFi speed running firmware 7.0.3 build 1260.
I recently upgraded the firmware to 7.1.0 build 1284 and WiFi speeds dropped by 50%. At first I thought it was an ISP issue, but Ethernet speeds were unaffected.
I have just reverted to firmware 7.0.3 and the WiFi speeds are back to their former status.
Try downgrading the firmware and see if that helps.
I have a Pepwave SURF SOHO MK3 router and was also getting poor WiFi coverage via its external antennas. Hooked up a Ubiquiti Unifi AC LR access point, got improved WiFi range but still unable to get the coverage at the master bedroom that is furthest away from the AP. Also the Unifi AC LR access point is in a disconnected status when I tried to administer it via the Unifi Controller. Not sure if this is due to my router settings but its one problem after another for me. Understand this is not the right forum to discuss Unifi product issues but hopefully this can help mamaffei.
I am running only one SSID:-
2.4MHz on channel 1, & 5MHz on auto (currently channel 36).
Using Apple Airport Utility on an iPad I can detect no other WiFi signal, so no conflicts.
Make sure you are on the same layer-2 with the controller and the AP. This is a common problem folks have. Might be your issue. For example, don’t have the AP on an isolated VLAN and your controller on a separate (also isolated) VLAN or the 2 cannot see and communicate with each other.
I can confirm that Wi-Fi speeds on Surf SOHO HW2 are off by 50% and more after upgrading from firmware 7.0.3 to 7.1. I did many carefully controlled tests and will post the gory details later. Worst case was a new Windows 10 Thinkpad laptop with an SSD. Same router same signal strength - got 60Mbps download with firmware 7.0.3 and 6 with firmware 7.1. That is not a typo, Wifi speed was down 90 percent.
UPDATE: This may have been a Wi-Fi channel issue. The router was allowed to pick its own 2.4GHz channel and it may have made a bad choice when booted. Lots of WiFi networks in the area.
I am having the same issues. My WiFi signal is weak and my devices attached to wifi keep going up and down. This appears to have worsened over the past month or so ( maybe having to do with the upgrade).
What exactly does this firmware upgrade fix? Are there some release notes? It doesn’t appear to be in the beta program.
@shankarr, we do have a bug for Wifi AP in v7.1.0. It happens on 2.4GHz and 5GHz. The Wifi throughput will be degraded due to this bug. The provided firmware here is to fix this bug.
This bug doesn’t affect the signal strength. So, the problem you are facing is different. Can you share what is the reading of the signal strength (-xxdBm) the Wifi client received?
I did upgrade the firmware but did not see any material difference and in fact saw what I thought to be a reduction in LAN speed. So I downgraded back to 7.1.0 build 1284.
In the -40 to -75.
My router is in my wiring cabinet that is enclosed, so I got extension cables for my antennas and have them outside the cabinet.
Things were reasonably OK for a while but recently the wifi client. (even a doorbell that is practically on the adjacent wall) refuses to connect.
I have logged a ticket 784340 open and looks like the other technician recommended upgrading to Build 1289 as well.
I just installed Mk3 firmware build 1289. There appeared to be some improvement. It feels snappier, and speed tests seemed to indicate 50% to 100% improvement, but who really knows? Speed is now adequate, if not as fast as my seven-year-old Airport Extreme 802-11n router.
Amateur observation: With the 1284 build it appeared I was getting nothing from the 5GHz radios; turn off the 2.4 gHz radios and speed tests showed 0 MB/s. With the 1289 build the 2.4 gHz and the 5GHz appear to be working together; reasonable speed with the 5 gHz radios only, but better speed with 2.4 gHz radios also turned on.
Suggestion: Allow WiFi AP Settings to select 802.11n-only, not paired up with “g” as in the current selection, “802.11ng.”
