Hey, I was wondering if someone could help me figure out a way to connect my LTE Tablet (LG G Pad X 8.0) to the Pepwave more reliably?
Basically the only reason I am using the Pepwave is because it allows me to have more than the 8 connections limited by the hotspot on the Android tablet. I use the 5ghz hotspot on the tablet and setup the Pepwave as “Wi-Fi WAN”.
I have 3 questions.
Could I use something like USB Tethering or an ethernet adapter to connect the tablet wired to the Pepwave?
Is there a different setup that would work better for me? I would love something that has better LTE reception that my current tablet, but I don’t think something like the MOFI would work with my current T-Mobile tablet plan since the MOFI is a “mobile hotspot” not a tablet.
Maybe an iPad would get better reception, or is there a way for mine or another tablet to boost its LTE reception using some kind of antenna? -
Do I even need a Pepwave SOHO for my current setup? Would just a regular, albeit nice 802.11ac router be enough to make the tablet hostpot recognize just one connection?
Couldn’t find this info using my search skills since I am not that versed in this stuff.
THANKS!!!
