Can the pepwave Surf SOHO be used to connect to a hotspot that is using WPA2-802.1x?
I’m currently using a normal router flashed with openwrt with that package (WPAD IEEE 802.1x/WPA/EAP/RADIUS Authenticator and Supplicant)
It is working very well but I would like to use the MK3 instead.
The hotspot is a belgian hotspot (proximus) with identity + password.
On the list this network appears as a 802.1x network
Thanks for any help!
